A/c not working Please help!!!
Old 04-23-16, 06:52 PM
fushiso88
fushiso88's Avatar
Default A/c not working Please help!!!
Hi lexus owners im new to this site and have a bit of a problem. I have a 07 is250 with a a/c problem. I'm not sure what it is or have to fix it. It shows on My nav. Screen check air conditioner connection, but everything else work on the screen just no ac. I started first by checking the fuses and they are all fine. So today I took the radio out to see if there was a plug not connected to the back of the radio and all are connected except one. Seems like there's a blue plug missing and I can't find it where I could plug up to the back of the radio. Could that be the missing plug thats not making my ac work??? Please help I've been without ac for a year now and not trying to go another summer without it...
Old 04-24-16, 11:08 AM
Gville350
Gville350's Avatar
No, not having connector would not cause your problem. If I remember right, that connector is used only for ML systems.
Assuming that all of the electronics for the A/C systems are fine, I'd start by seeing if there's a leak in the system somewhere.
Old 04-24-16, 12:34 PM
fushiso88
fushiso88's Avatar
Do you know where would I look for leak at? I thought it was a connection problem because my auto ac light that shines green doesn't even come on when I press it....
Old 04-26-16, 12:56 PM
Gville350
Gville350's Avatar
When it comes to A/C systems, I've got zero knowledge on DIY fixes. It would be best to take it somewhere that has all of the proper equipment to look into this for you.
Old 04-26-16, 02:48 PM
fushiso88
fushiso88's Avatar
Alright thanks hopefully somebody on here will know the deal with my problems
Old 04-26-16, 03:21 PM
Zmon
Zmon's Avatar
IIRC, it's probably a relay problem. Swap the A/C relay with the horn relay and see if it works. If it works, buy a new/used relay.
Old 04-26-16, 03:31 PM
fushiso88
fushiso88's Avatar
Okay will do soon as I get home
Old 04-26-16, 05:32 PM
fushiso88
fushiso88's Avatar
Wasn't the relay unfortunately, wish it was. Checked all the fuses they're all good. Im About to give up on this car.
ggaines10
GX - 1st Gen (2003-2009)
08-22-21 11:02 AM
singlelife
03-11-16 08:12 PM
06is250Lex
01-04-14 10:22 AM
fatboi
05-31-11 05:05 PM
Quick Reply: A/c not working Please help!!!
