07 A/C light flashing, magnetic clutch relay need replacing?
Hey all, just picked up a used 07 250 and noticed the AC light flashing and no cold air coming out. I've had this happen in my older es300's and it was always easily resolved by putting in a new magnetic clutch relay. I looked in the engine compartment fuse boxes and didn't see any relays marked similar to the 300, but I did see an ac/compressor relay. Do you guys know which relay should be checked? Any help in identifying the right relay or fuse is appreciated. Already did a search but couldn't find anything specific to this problem for second gen 250's. Hopefully it's just a relay issue like on my 300's.
Hi OP,
If you are still around, can you tell me how you resolved your issue?
I seem to be having a similar issue..
Thank you.
