ABS and traction control light on
New here.
Trying to get info on what the issue might be. I have a 2012 Lexus IS 250 F I purchased it 2 weeks ago and the ABS light and the little car with lines symbol, which I googled and it says traction control light are on at all times . Amy one have an idea of how much will I need to fix these 2 problems. I don't have warranty. I have to pay out of pocket😔😔😔
There are many reasons the traction control light will stay on all the time, including if the check engine light is on for example. You will need to check the DTC's (error codes) using a scanner before any meaningful discussion can be had about what might be wrong.
There's pretty much nothing anyone can say beyond that.
Jeff
Jeff
Azeri89
03-25-17 10:35 PM
bofronado2
04-16-14 01:58 PM
