Wheel bearing noise?
Old 04-27-16, 06:40 AM
NikonGuy
NikonGuy's Avatar
Default Wheel bearing noise?
Some backstory. Last fall had a rock hit inside of my front driver wheel and took a small chunk out of tire and wheel. I only found this out when I swapped it out with my winter tires in Nov 15. Everything was driving fine. I planned to buy new tires when Spring came along. So a few weeks ago finally got two new tires for the front and didn't think anything of it.
I was getting bad vibration. Tire place said front left tire was bent. So I take it to a wheel repair place and they are in the process of fixing that wheel. So I put my snow tires back on hoping it would cure the noise.
But the noise is still there. You can hear it even at 5mph but gets real lout around 35-40mph.
Sound is coming from rear. Could it be wheel bearing issues?
Check out video below. Not sure how much it picked up but just think 2-3 times the volume on the video. That is how low it is. Kind of a whirring/helicopter sound. Some times it gets so bad the trunk rattles a bit.
I've eliminated tires as I had two sets of tires on the car and still exhibiting issue:
https://www.youtube.com/watch?v=LZhZ...ature=youtu.be
Old 04-27-16, 11:57 AM
92fs
92fs's Avatar
I recently had 3 out of 4 bad and had them replaced. It drives like new and no more noise. I would have it checked out because it was causing uneven tread wear as well.
Old 04-27-16, 11:59 AM
strikeraj
strikeraj's Avatar
when you jack up your car and get a grip at the top and bottom of the tire and give it a shake, does it rock?
Old 04-27-16, 01:47 PM
NikonGuy
NikonGuy's Avatar
Yeah I'm going to try that tonight
Old 04-27-16, 01:50 PM
Gville350
Gville350's Avatar
Is it mph-dependent? Meaning, the tone of the noise increases along with your speed?
Old 04-27-16, 02:35 PM
NikonGuy
NikonGuy's Avatar
It definitely changes with speed. Even coasting at 5mph I can hear it. Gets louder with speed and around 40mph is the loudest but still very noticeable at 60, 70, etc.
And doesn't matter going straight or turning, noise is there
Old 04-27-16, 07:10 PM
srt1
srt1's Avatar
Yes it sounds like wheel bearing. Turn left and right. When you do this and it sounds LOUDER it will then tell you which side is bad. So if you turn right and hear it, that means it's the left side that's bad and vice versa. Hope this made sense.
Old 04-28-16, 12:45 PM
Gville350
Gville350's Avatar
Yeah, 90% certain it's a wheel bearing; but also check that nothing in the braking system is at fault...like a bent rotor dust cover touching something it shouldn't.
173rd
12-09-22 05:26 AM
vgdti
04-13-16 07:35 AM
biacs
11-21-15 06:35 PM
DJohnson62
02-11-14 02:29 PM
430BOB
North Texas Lexus Club
02-22-12 10:19 PM
Quick Reply: Wheel bearing noise?
