Hub Rings Question
Hello,
I recently acquired a set of Rays wheels which I am trying to fit onto my IS250. From the research that ive done, the wheels are 66.1mm and my hubs are 60.1.
If I use hub rings that are 67.1-60.1, would they work without any modifications?
For the ISx50 = Hubcentric Rings - 73mm to 60.06mm
http://www.workwheelsonline.com/hubc...to-736006.html
Recommend Plastic
The Aluminum tend to have issues when mounted EX : getting rusted to the hub/rotor
Recommend Plastic
I had aluminum centric ring and never have any problem with it. Plastic one isn't good in my opinion. I bet lot of us here use Aluminum instead of plastic. I could be wrong
P.S some member here on ClubLexus know how i drive so.........aluminum is my choice
Also went hcring-less for a week while they were getting it in stock... didnt notice any vibration, but put the rings on anyway.
i had both aluminum and plastic centric rings but i prefer aluminum cuz seems to fit more snug compared to the plastic one i had and the plastic one had a bit wear on it after awhile for some reason..
I've run plastic hub rings from my local tire shop for years throughout various vehicles... I originally went with aluminum but when buying another pair went with plastic as I didnt see any benefit in paying more.
Thanks for all the help and the links.
I tried test fitting my wheels over the weekend with the 67.1-60.1 ring and like Jeff says, it didnt fit my car.
I ended finding some cheap rings on amazon the same wheel/hub size as my G35 rims. It is now a waiting game.
I decided to go with plastic rings as ive read online and posts here that aluminum will rust and seize to the hub. Since I live in Canada and our roads are salted AF, the safer bet was to go plastic.
2017FSport
RC - 1st Gen (2015-present)
04-01-19 05:39 PM
