Car would not start
I have a 2007 is250 , Yesterday I got in my car heading to work an pushed on the brake to start my car and the brake pedal was tight. Pushed the botten an all you hear is a click, dose not start. The lights come on the navigation works to but the engine dose not start. I got the battery just replaced two months ago. What could it be?
What he said ^
Im assuming your car isnt even turning over? What happens when you try to turn it over? A fade in power or everything is fine
My RSX killed off 3 batteries with a poorly done big 3 upgrade done by the previous owner. I know you just replaced your battery 2 months ago but check your batt and also check your lines going to your alt as well.
Sorry for the additional post,
Forgot to mention I checked the fuses and all connectors,
I killed the battery trying to start it over the last 2 weeks.
Removed battery to recharge it , hoping it might reset the ecu.
Thanks
Thanks
