Dealer recommending carbon cleaning 2008 is350
Hi,
I took my IS into Lexus to take care of oil maintenance and aux noise and the Lexus dealer is recommending I do a carbon cleaning on my 2008 is350. I've searched for threads and I know it's a problem on the is250s and the is350 shouldn't have the same problem because of the dual injectors. The dealer was quoting around $300 to clean.
I'd like to hear your thoughts if the carbon cleaning is needed or not.
Thanks.
-T
Thanks.
-T
Hi,
Thanks.
-T
Thanks.
-T
Hi,
Thanks.
-T
Thanks.
-T
litesoarer, it should be the same case with your LS, I believe your 460 (or 600h?) LS was offered with the same d-4s system (port + direct injection) so you shouldn't have carbon buildup.
just give it a full rev once in a while (of course when the engine is fully warmed up)
Despite the IS250 really having the bigger problem of the two, the IS350 does still build up more carbon than a port-injection only car. It's not usually enough to start causing misfires and things of that nature like it does on the IS250, but if you've got high mileage, it might not be a terrible idea.
Still, if the car is driving fine, I can't really see why they would be offering it to be honest. (Possibly because of money, lol)
Jeff
Jeff
JunLi
07-14-16 12:19 AM
MikeZero
12-26-14 03:03 PM
