Anyone run 17x7.5 on IS350? Will they clear?
Will these fit an is350 & clear the brakes? Seems like a good deal figured if they fit I will use them for my winter setup........
http://www.ebay.com/itm/Set-of-4-Whe...-/182112464651
17x7.5 wheel
Item Specifics
BrandRWL
Bolt Pattern5x114.3
Manufacturer Part Number270
Hub Bore60
Rim MaterialAlloy
Rim StructureOne Piece
Rim Width7.5
Quantity4 Pcs
Rim Diameter17
FinishHyper Black
Number of Bolts5
Item Number182112455164
CategoryWheels
in eBay Motors
17x7.5 wheel
Item Specifics
BrandRWL
Bolt Pattern5x114.3
Hub Bore60
Rim MaterialAlloy
Rim Width7.5
Quantity4 Pcs
Rim Diameter17
FinishHyper Black
Number of Bolts5
CategoryWheels
in eBay Motors
Yes, they should clear. I run 17x8" in the front for my snows and they're fine. Just gotta make sure they don't curve in on the inside but if they're Lexus wheels (or replica's) they should be okay.
alwayzspeedin
02-18-09 10:30 PM
turbosix
05-12-07 12:21 AM
