IS250 Walnut Blasting Valves DIY
The walnut blasting procedure is the same process but the removal and replacement of parts is a much different procedure.
Going off what they perceived the job as after they looked into it. Magically I'm the only one who has a BMW shop willing to do the proceedure. They came to the conclusion thats its not all different (yes surprise...they are not identical as far as engine part removal) the concept and process is. Which is what i leveraged in order to agree to take on the idea.
Ive had 2 IS250s done so far and theyre able to do it all in a matter of a few hours. So when people are saying shops are turning them down. I simple tell them what my shop told me. Correct, they had to biy a 20 dollar adapter (which ive noted in other carbon build threads).
WOW, that is scary and the furthest thing from the truth. A BMW 335i N54 or N55 engine is nothing like a Toyota 4GR-FSE or any GR series motor for that matter. The BMW motor is a BMW designed 3.0 slant 6 cylinder turbo motor where the Toyota GR motor is an NA Toyota designed V-6 and the walnut blasting adapter is totally different.
I know this is an old thread but this is good. Just did plugs on our 250 and they need some love.
I'll start with CRC valve cleanr and or Seafoam. If no improvement then I'll step up to the DIY walnut blasting.
SuperCPA
North Texas Lexus Club
12
08-22-11 03:43 PM
