Audio not working
Audio not working
Started the car this morning and the audio won't turn on. Pushed the button a few times and nothing happened. Tried ejecting my cd's and nothing is happening. I checked the fuses (three different ones at two different locations, according to the manual) and none of them are blown. Don't really know what else to do. Not crazy about taking it to the dealership. Anybody have ideas on what's going on?
I'm having the exact same issue right now. Didn't even notice because I only use the Auxillary audio, apparently that works fine. Very interested to see if there's a solution. OP, does your Auxillary audio work?
I'm not sure if this helps but my car was in storage for the winter and the battery was dead when I took it out two weeks ago. Jumped it and it works, I'm driving it daily and no battery issues. I have a feeling the CD player broke when it was being jumped, I had a similar issue happen on a different car.
Also, I think I hear the current CD spinning, but does nothing. And my CD menu display is stuck on CD 1 and does nothing when I click other CDs.
Last edited by veejaay24; 05-16-16 at 10:42 AM. Reason: Additional Symptoms of failure
NOTHING works. I usually use the auxiliary also. Probably wouldn't even care if the cd player didn't work anymore. Wish I was in your situation!
I thought/hoped it might have been just the fuse, since the fuse to the fog lights just blew last week. I would be more than happy to change the deck if I knew that was the problem. I'd just hate to blow $200 on a deck on Ebay and still not have it work.
Only thing I can think of for you to do is disconnect the battery for a while, then connect it back and see if the deck will maybe reset? That sucks
My buddy had the same issue. I took my Mark Levinson amp and hooked it up to his non Mark Levinson system and his stereo worked. He sent the amp off for repair instead of replacing. Major difference in cost.
empringham
12-27-14 09:39 AM
