What size rear spacers with stock wheels?
On my stock '07 IS350, I'd like to space out the rear tires to fill the wheel wells a bit more. I'm running 255's on OEM 18's. Have any others done this and if so, what size pushes them out but, not to the point where I might have fender contact? Also, do I have to cut the factory studs or will the spacers cover them fully?
Thanks - Todd
Thanks - Todd
There are a few decent brands of spacers. H&R makes nice ones, but not exactly what I've recommended here (everything under 25mm requires extended studs with their spacers). I've ran Ichiba V2's for about 4 years on my IS (20mm), and I used them on another IS (15mm) as well without issue.
Jeff
Jeff
Take a look at this thread: https://www.clublexus.com/forums/is-...nd-ichiba.html
I'm running 15F/20R with extended studs on factory size everything. No issues.
Thanks,
Todd
RTIS250
CT 200h Model (2011-2017)
33
12-07-15 10:00 PM
JDKane527
03-24-09 07:23 PM
