Warning light
Old 06-02-16, 07:44 AM
Knarf916
Knarf916's Avatar
Default Warning light
on startup, the warning light comes on and then turns off. i recently had an oil change and i cleared the maintenance req. light but the warning(an exclamation point) comes on at start up. what can it be? i've checked tire pressure. its fine. if anything, pressure might be higher than required.
Old 06-02-16, 07:58 AM
AyeBird
AyeBird's Avatar
If it turns off right when it says "check completed," that's normal. Correct me if I'm wrong here but, that's just your car doing it's normal check that it does when the engine is started. It's sort of like when you turn on your car and all of the warning lights come on until the engine turns over and they all turn off. Nothing to worry about
Old 06-02-16, 09:36 AM
Knarf916
Knarf916's Avatar
yea, it shuts off right away. never noticed it before.
Old 06-02-16, 11:35 AM
Tro209
Tro209's Avatar
Yeah you got nothing to worry about, the car always does that. However if you did have a problem then not only would the red triangle light up, but the car would also give you a message indicating what it is. Such as when you have to perform oil maintenance or have low tire pressure.
Old 06-02-16, 01:29 PM
Knarf916
Knarf916's Avatar
good to know. thx
Jlesz
10-06-13 09:37 AM
k954triniz
IS - 1st Gen (2001-2005)
01-11-12 04:14 PM
LexusTime2
01-20-07 01:07 PM
91SHOman
Performance & Maintenance
03-03-05 09:40 PM
palmerwmd
Maintenance
10-31-02 10:28 AM
Quick Reply: Warning light
