Speedometer/Instrumental cluster rattle
Old 06-06-16, 10:12 AM
20LS01
20LS01's Avatar
Default Speedometer/Instrumental cluster rattle
Hi
I have a 2010 lexus is250. I have a rattle which appears to be resonating near the bottom of the instrumental cluster. It doesn't do it all the time but it does sometimes and it's quite annoying. Does anyone else have this rattle and know where the issue lies?
Old 06-06-16, 11:18 PM
nosurprise
nosurprise's Avatar
Yes, I had a loose yellow clip inside the lower panel (close to the *****) that cause it to make a rattle noise. After I put it back in, the rattles go away. In the winter, there is also a small rattle between the instrument cluster hitting the bottom of the plastic -- if I press on it, it will stop. I just need to remove the lower panel again and put some felt tape there -- too lazy to do that again.
Old 06-07-16, 12:40 AM
P128sniper
P128sniper's Avatar
If you have a 2is get use to the rattles, u just have to get use to them cause these cars are basically known for their rattles. Not really but still, lots of rattles...
Old 06-07-16, 04:15 PM
henry1229
henry1229's Avatar
Yes. The instrument cluster is slightly loose and rattles around against the inside of the dash and the metal supports. I bought a block of foam, removed the dash under the steering wheel, and stuffed large chunks of the foam between the cluster, the metal supports, and anything else that it could potentially rattle against. I had to really push some of it deep into the back of the dash but it was so worth it. That rattle was immensely annoying.
Old 06-07-16, 07:34 PM
Wunko
Wunko's Avatar
I have the rattle too on my 2011 IS350 especially with the temperature changes. I tried putting some electric tape between some gaps but that hasn't worked so far.
franko9217
02-27-17 05:56 PM
Luxor
GS - 1st Gen (1993-1997)
06-24-15 06:31 PM
GeoG
SC- 1st Gen (1992-2000)
19
06-16-15 10:47 AM
Stun350
03-12-12 09:46 AM
Sean1692
01-23-07 04:35 PM
Quick Reply: Speedometer/Instrumental cluster rattle
