2007 IS250 RWD 18x8 with 225/40 R18 -is it ok?
Old 06-10-16, 02:10 AM
shomci
shomci's Avatar
Default 2007 IS250 RWD 18x8 with 225/40 R18 -is it ok?
hey guys,
my question is, "will those rims fit"?
i have aftermarket wheels on my lexus an i could get oem 18"s but all of them are 8" wide.
ive read somewhere that RWD in the rear should be 8,5" with 255/40 R18
can anybody confirm the proper sizes for RWD IS 250 with 18"?
can i put on 225/40R18 for all 4 wheels? wouldnt it be a problem?
thanks
Old 06-10-16, 04:38 AM
badx33
badx33's Avatar
Hello there, the stock wheel and tires size are like this for the rwd IS.. The front wheels are 18x8 and the rear wheels are 18x8.5 I dont remember the offsets but I think they are in the 30's. Now the front tires should be 225-40-18 and the rear 255-40-18. In the past I have used a 245-40-18 on the rear wheels. Hope this helps.
Old 06-10-16, 07:26 AM
sktn77a
sktn77a's Avatar
The standard tire width for an 8" rear wheel is 245 but a 255 will fit just fine.
Old 06-10-16, 11:32 AM
strikeraj
strikeraj's Avatar
Originally Posted by shomci
hey guys,
thanks
if you want to do square setup, I would go 245 or 255
225 at the rear is not enough meat in my opinion (unless it is winter tire which you won't push it anyways, and skinny tire helps digging into snow
Old 06-12-16, 02:32 AM
shomci
shomci's Avatar
thanks guys!
Old 06-23-16, 03:40 PM
Metaxa07
Metaxa07's Avatar
i ran the same size on the wife's all arround to help life of tire. those were on the 17", which was the same size rim all arround, but different factory tire size.. dont know why they did that.
Old 06-24-16, 01:31 PM
sktn77a
sktn77a's Avatar
245 or 255 won't fit on the front - the largest you can go is 235 on an 8" rim with the correct offset. Even then, several manufacturers 235s rub on the front liner.
Old 06-24-16, 10:26 PM
MWIS350
MWIS350's Avatar
My is 18X8 front and rear and so far so good.
Old 06-25-16, 07:38 AM
RandyIS250
RandyIS250's Avatar
you want your car looks nice sick and wheel sticking out without needing to install wheel spacer ?
rim 18x9 235/40/18 front : 255/40/18 rear offset 35
for AWD 18x9 235/40/18 offset 35 all around front and rear
I bought the wrong rim before i figured out our car GSE20 and 21 suspension chassis
hohohong
12-03-15 07:13 AM
garroids
03-18-14 03:54 PM
panda08
02-25-12 12:28 AM
rfx45
Wheels, Tires & Brakes Forum
09-04-07 10:33 PM
iain
06-14-06 09:42 AM
Quick Reply: 2007 IS250 RWD 18x8 with 225/40 R18 -is it ok?
