PS Anthracite Gray
Old 06-27-16, 05:04 AM
mandyfig
mandyfig's Avatar
Default PS Anthracite Gray
Who has painted their OEM rims with PlastD Anthracite Gray+Glossifier? How do they look with dark colored IS?
Old 06-27-16, 06:21 AM
MAizz
MAizz's Avatar
Can't say for sure on the dark colored, this is the anthracite without gloss. IMO much better than matte/gloss black because you can still see the detail of the rim.
Old 06-27-16, 06:33 AM
top5
top5's Avatar
Dont waste your time with the glossifier. Youll hate it. It made my rims look tacky and I removed it immediately.
It looked like someone tried applying wax to matte rims.
Old 06-27-16, 06:49 AM
MAizz
MAizz's Avatar
+1 just clean with soap and water, there is enough shine in the dip color itself when clean
Old 06-27-16, 09:26 AM
jjc250
jjc250's Avatar
No glossifier, Excuse the dirty car
Old 06-27-16, 09:41 AM
mandyfig
mandyfig's Avatar
Shoot! Why did I not ask this question prior to purchasing the pack!!! I did the 4 Anthracite plus 3 Glossified PACK!
They all look good! Thanks for sharing.
I am going to do my RX350 first, which is GRAY metallic body color, it has the 5 spoke rim, which is not as attractive to start with.
Then am thinking of doing it on my IS which is Black in color.
Old 06-27-16, 09:42 AM
mandyfig
mandyfig's Avatar
Perfect!!
This is the picture I have been searching for. Thank you!
Old 07-05-16, 04:55 AM
mandyfig
mandyfig's Avatar
Well had time over the holiday weekend and did it! I could not get the gloss up with several coats. I will take pics and post. Ended up taking the sets off and putting them on bar stools, much better.
The RX350 I did it with the wheels on and it almost broke my back. And i have paint drip.
Old 07-05-16, 04:56 AM
mandyfig
mandyfig's Avatar
I must say, at night I like it, this morning I am looking at it and I say…hmmm, Black with dark gray rims…hmmm
Old 07-05-16, 06:02 AM
mandyfig
mandyfig's Avatar
Closer look...
It is taking time me to appreciate it...
I need some feedback...I wish I would have gone Gun Metal...
Old 07-05-16, 07:31 AM
MAizz
MAizz's Avatar
Closer look...
Don't do gunmetal, looks awful as a stand alone color, it is the same as anthracite essentially without the microflakes. If you haven't already, use Dip Coat on it (turtle spray wax is close), it make it shine and pop a bit more in the light and gets rid of the rubber feel.
It looks like your spray was perfect though, maybe a learning curve from the RX
Old 07-05-16, 07:38 AM
mandyfig
mandyfig's Avatar
MAizz, got that right from the RX. My finger is sore...I should have bought a trigger adapter. Lesson learned.
Will any other wax work? Also I can see rough ridges, will it not be a challenge in buffing it?
Old 07-05-16, 07:55 AM
MAizz
MAizz's Avatar
side note, the spray trigger is more comfortable but I'd prefer the can by itself, more control but thats personal preference.
Most spray waxes should work, I remember using turtle before Dip Coat came out, dip coat is by far the best option though. with any product you use, spray on the dipped surface and your towel/microfiber and wipe off, no need for elbow grease or any effort really.
If you are trying to buff it like you would paint to get rid of ridges or runs, you CAN... but you will scratch/mare the surface. Wet sand with 800-1000 grit, plenty of soap and water.. It works great if you are applying another coat or different color on top because the surface beneath will be smooth, but if you don't apply a coat on it will ruin the look.
Old 07-05-16, 09:41 AM
mandyfig
mandyfig's Avatar
Thanks for the info. I rely on AS303, it should work in this case, too?
jdanielca
09-05-18 07:08 AM
areukhmer
08-25-10 10:04 AM
tpizarro
02-01-07 07:16 PM
DJ SprinklesNJO
Wheels, Tires & Brakes Forum
09-30-05 08:32 PM
dwoods420
02-22-05 10:00 AM
Quick Reply: PS Anthracite Gray
