Need help on what tire size to get for 2008 IS250 AWD?
225/35/19 offset 40 or
wanna go big ? 235/35/19 offset 35 , your wheel will be like those BWM M-series and Mercedes AMG
i'm running on 225/40/18 because i don't wanna spend too much i'm IS250 AWD as well.
Keeping it Real
I've run 245/40R17's on the front for years with the RWD Sport suspension (lowest factory 2ISx50 suspension) without any rubbing whatsoever. I've also been running tires that typically fit wide (RE-11A and now RE-71R).
I would expect some 255/40R17's would likely clear the front on an AWD pretty well, but 245/40R17 is definitely not an issue.
Jeff
Jeff
I finally purchase f-sport forged gunemetal wheels ,there all are 19x9 offset 40 ! On discount tire is has the original size what came on the car which is 225-45-17 and has a plus 2 column which says 235-35-19 is the tire to go with to have the same rolling diameter!
