IS350 Serpentine Belt
I am seeing and reading on how easy it is to replace the serpentine belt on the is350. I have a 2010 with 87,000 miles and it is the original belt. My questions are as follows:
1. Do I need to know anything special with a 2010 is350 that may be different than a different year is350 for this diy?
2. What belt are most people having good luck other than oem? Dayco, Bando, etc .... Suggestions?
Thanks!!
Danais350
Thanks!!
Danais350
The entire belt replacement is very basic :
1) Remove the plastic covers to access everything you need to.
2) Using what I think was a 14mm socket on the tension pulley, turn the wrench to the direction where it adds slack onto the belt.
3) Remove belt.
4) Run the NEW belt around all of the accessories you can; this will be all except one.
5) Add tension onto the tensioner pulley again in the same manner as previous to allow you enough slack to run the belt onto the last accessory.
DONE!
I run an OEM.
3) Remove belt.
DONE!
I run an OEM.
babaganoos
RX - 3rd Gen (2010-2015)
02-25-12 09:25 PM
