90k mile service for IS350
Yea pretty much same service minus spark plugs unless you didn't get them changed at at 60k. Don't spend 1k at the dealership most of the things dealer will charge is for inspections. All you need to really do is oil change, oil filter change, air filter change, cabin filter change, brake fluid change. I would definitely do the air filter and cabin filter yourself, shouldn't take more than 10-15 min even for the least experienced person. I take mine in for oil change to dealer and brake fluid I have a local shop that I trust do it. Shouldn't cost more than $200-$300 for parts and labor for all of that. Most likely even less than that, oil change at my dealer is $75. Air filter is $17 at auto zone and u can do urself. Cabin filter is $10 and u can do urself. Just a matter of how much they will charge you for brake fluid change buy should be more than $100
The maintenance schedule and what needs to be done is generally listed in the manual. You can also go to your dealer website and schedule service and it should suggest the 90k service which will tell you what they do. Inspects everything, lubes everything, retorques driveshaft, brake fluid change, oil, air filter, cabin air filter, replace keyfob battery, All things you can do in your garage on a Saturday for 10% of what they want.
My advice? You're nearing 100k. If you haven't already done all your fluids (brake, coolant, transmission, rear dif), and your spark plugs, I'd do them.
Forum Administrator
HankMoody, P128Sniper - exit this thread and do not respond to each other in future threads (posts removed).
