ECM Part number
Old 07-07-16 | 06:48 PM
HilarioPen's Avatar
HilarioPen
Default ECM Part number
Hello, I recently bought a 2006 is250 AWD and I was told that the engine computer (ecm/ecu) was bad and i have to replace it. I did some research and i think i found the part number for it (89661-53562), my problem is that it cost $400 at a used auto parts place and i really dont want to buy the incorrect part. Can someone out there double check for me if its the correct one, please? I can provide additional information if needed.
Old 07-07-16 | 09:31 PM
nosurprise's Avatar
nosurprise
You can do a search here: http://www.mylparts.com/
It looks like it may be the right part; you can call them to be sure. It's a lot cheaper there too; and brand new. I haven't ordered stuff from them before but hear they're good.
Old 07-08-16 | 07:21 AM
Bichon's Avatar
Bichon
Super Moderator
No offense, but you may want to clean your eyeglasses.
$1,114.58 is definitely not cheaper than $400.
It also looks like that part is for an IS350, not an IS250.
Old 07-08-16 | 09:06 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
The correct new replacement part is 89661-53595.
If you are looking for a used ECU, the following are correct part numbers for a 2006 IS250 AWD:
89661-53590
89661-53591
89661-53592
89661-53593
89661-53594
89661-53595
The part number you posted (89661-53562) is for a 2006 IS350 RWD.
Jeff
Old 07-08-16 | 08:19 PM
nosurprise's Avatar
nosurprise
I was looking at the red number
Old 07-08-16 | 10:05 PM
DickH's Avatar
DickH
How do you know your ECU is bad? What problems are you having? If you want a cheaper ECU, you should be able to find a used one on eBay for 200 so. Heads up, the vin will need to be rewrote to match yours and you will need to have the immobilizer reset to recognize the swapped ECU.
Usood89
08-22-14 12:40 PM
BigJohnLs
07-11-11 09:20 AM
Wesley81
03-23-09 06:54 AM
LongGS4
06-01-08 11:45 PM
5gears-IS
Great Deals
09-11-06 03:35 PM
