Changed battery - now radio/AC won't work
Same here
All
the fuses are working on clean,clock and hazard lights come on when I click the button but everything else is not working at all Idk why
any suggestions
Same issue
OK,
what you have to do is.
1. completely removed your navigation unit (i bet you have message "external system is not connected ..."
2. plug it back in (but don't put everything back together yet) and turn on ACC - everything will be working fine again but as long as you start your car the problem will com back
3. Don't panic, you have to remove your unit once more time - first time for NAV, A/C, and Radio initialize and linked all together - and reconnect it.
4. Reset your ECU - removing negative terminal for about 30 second only- your unit will be fully working again. PM me if you need more help!
jnolan72
GX - 2nd Gen (2010-2023)
01-04-19 07:11 PM
LEXI2006IS
05-16-14 03:33 PM
