need help 4 constant 12vdc on acc
so I'm trying to get a system going and I am trying to look for a constant 12vdc from the accessory fuse box area. I tested all ports and nothing is above 12vdc. is there a spot on the IS350 that gives a constant 12vdc on accessory only (when key is turned to on) not a constant 12vdc like from the battery. any help would be really appreciated. thank you.
You would want to use a relay. You can get 12v from the fat white wire that plugs into the fuse box and use accessory to trigger the relay.
What are you hooking up anyway?
accessory is GREEN
http://www.the12volt.com/installbay/...asp?tid=103587
12 VOLTS Go to Battery
IGNITION Yellow At Power Module (pin-35) +
posted_image The Power Module is located behind the glovebox on the far right side
IGNITION 2 Lt.blue At Power Module (pin-34) +
ACCESSORY Green At Power Module (pin-11) +
STARTER Blue At Power Module (pin-15) +
STARTER 2 Violet At Power Module (pin-17) +
TACH SIGNAL White At diagnostic plug under driver's side dash AC
LOCK blue At switch assembly in driver's door -
UNLOCK White (double pulse) At switch assembly in driver's door -
DOORPIN Violet or Pink At driver's side Body ECU -
posted_image The driver's side Body ECU is part of the fusebox under the driver's side dash. This wire is located in a 10-pin connector.
TRUNK PIN Green or Blue At passenger side Body ECU -
posted_image The passenger side Body ECU is part of the fusebox behind the glovebox. This wire is located in a 28-pin connector.
TRUNK RELEASE Pink At passenger side Body ECU -
FACTORY ARM Arms with lock wire
FACTORY DISARM Disarms with unlock wire
BRAKESWITCH Red/black At switch above brake pedal +
PARKLIGHTS Yellow In 28-pin plug on driver's side fusebox +
HORN White At top of steering column -
VSS WIRE Blue At Audio Amplifier in passeger side of trunk
MamadIS
09-26-21 08:35 AM
RyGuy0062
11-09-17 09:38 PM
