Check VSC/ AWD, ABS , TC lights on
I know there are several VSC threads but my search didn't find my same issues. Driving to work yesterday and these all came on, car doesn't seem to drive any different.
I have an 08' IS 250, AWD with 101k on coil overs with 19X9.5 on all 4. Disconnected negative terminal and lights are still on. Anyone with any input would be much appreciated.
Have you've checked if one of your ABS wheel sensors is bad? This happened on my GS400. If you have access to a ABS scanner that would be great. Also you can pull one wheel off at a time, and check resistance with a OHM meter at the connector.
akafixture
02-13-20 05:28 PM
