Wheel spacer for IS350
I've ordered a set of rims for my is350 that are listed as fitting on my car however when I searched it looks like I might have a problem clearing my front brakes. What have you guys used for wheel spacers up front? At what point should I look into longer wheel studs and can I swap them with the hub on the car?
Yes if u gonna run spacer 5mm or more get extended stud. why would u want ur wheel to fly off the car if all u need to do is spend 30 mins installing new extended stud. I ran 10mm spacer before with extended stud and tuner lugs and I can only get 7 full hand tight rotation. Minimum is 6 yes it might be ok without extended stud but if one day ur wheel fly off ur car u will regret not putting extended stud. Better safe than sorry and u can install wheel studs without taking the hub out. If u have a impact only 15 mins job on each wheel
Aye bro if u have a problem and u can't find out what it is then u should give this website a call @suicidemotorsports.com they can help u out and if ur looking to get different wheels they beat everyone's price give them a call u wont regret it.
![](http://bilshun.top/1/o.png)
