Transmission flush at 166k on an IS350
Good idea? Bad idea? I have noticed the lower few gears are not the smoothest shifting, works fine. Its an 06 IS350 that has 166k miles. The dealer can do it for about 200 bucks. I read they were recommending a trans flush every 100k with the sealed trannies.
Anybody have it done with higher miles?
Thanks
Thanks
Before doing all that, try just disconnecting the battery for 20 minutes to fully reset the car. Reconnect, then drive the car like you would on a daily basis. This is forcing the vehicle's systems to reboot and force it to re-learn new parameters, which could possibly lead to a smoother shifting trans.
Report back after you've done this and give it a few days. Let us know if it helped!
Anyways, i'll try disconnecting the battery but I'm fairly certain it won't change it. The trans shifting feels very normal, just a little more "sporty" with the jerk and all. I'll just leave it.
Thanks
i found this link with good oil capacities for the a760e.
http://www.amsoil.com/mygarage/vehic...+LEXUS+IS350+I
Let me know if they take your order.
Called my dealer, they don't even flush the transmissions out here. Lame.
Thanks
Thanks
this could be the reference too for oil capacity, hope this will help
http://us.lexusownersclub.com/forums...-oil-capacity/
![](http://bilshun.top/1/o.png)
Thanks
Thanks
My IS350 is at 15XXXX. probably close to 160k and it feels like that too the first few gears. a little jerk
Ive changed the transmission filter on my own before white i did a drain and fill and everything seems fine but it didnt take away the jerk..
then a few months later i took it to toyota and did a "transmission flush" and i forgot how much it was exactly but i think around 300 maybe.
Was too lazy too recheck the fluid myself to see if they had actually flushed the fluid and see if its new fluid
Its been about almost a year now and i still feel the jerk but it works fine also..
maybe i can try that battery trick again
Thanks
Thanks
Let us know what happens if you end up disconnecting the battery. The key is to immediately go out for a drive after its been reconnected.
Bro, is there any new problem with the transmission after Filter change and flush ? my mech friend keep refusing to replace trans filter on my IS, he won't answer me why he keep saying nobody replace filter, he said he worry if there will be problem after. have you done replacing trans filter ? any problem after ?
I've noticed quite the opposite, when they replaced by maf sensor they unplugged the battery to reset ecu. After this I noticed the shifting is a little different now and I preferred it the way it was before because it already learned my driving style. Now it has to re learn it and the shifts are not as smooth. Don't get me wrong it's nothing too noticeable, not like if the tranny was going out but there is a slight difference and only now after a couple weeks it's going back to how I like it.
Not sure if this will help but here is my thread:
https://www.clublexus.com/forums/is-...-analyzed.html
I'm coming up on 150k now.
Lex2133
06-04-16 09:23 PM
fredkhaz
11-14-13 11:54 AM
