VSC Light + ABS, Brake, and Traction Lights
So I have the same problem and it's intermittent. A friend of mine that works at the dealership say's they can still find out what the error logs say's even tho it's not showing up anymore, and we find out it's a bad wire/connection or something underneath near the brake pedal. I never got it replaced since it goes away and only shows up every couple of months for a day or 2, then goes away on it's own.
Ok thanks for the heads up Badboye. Yeah maybe it was just my obd2 scanner. Maybe ill go in and get it scanned by an professional. Its probably not a big deal i just wanna know what it actually is thats causing the issue.
Brake, ABS. Trac off, vsc (I think)
these 4 lights kept coming on in my 2007 RX350, had it checked at the Lexus dealership and they said it is the brake light switch. This happened about 3 years ago and it was same thing. Had it replaced and is fine now.
When this happened to me I just cleaned the gas cap off and it somehow disappeared. Called the dealer and that's what they said I should do. It did appear two more times after I refueled, just did that again and haven't seen it. Don't know if this will work for everyone else though.
[QUOTE=Rishabh1;9591327]The dash lights for VSC, Abs, Brakeep, and Traction control have been popping on. Occasionally when I switch lights from auto to on. Other times, just on start. Shop replaced the sensors, but this still pops on. Thoughts?
Did you find?
2006 IS350[/QUOTE
Did you find?
2006 IS350[/QUOTE
dwb
07-22-13 06:15 AM
