How much longer will my car last? (IS 350 2007)
You're getting a little anxious about nothing, really. Alternators tend to go around the 8 year mark in these cars, and occasionally they'll take the battery with it too. It's a wear and tear part, some people get 100k+ out of them, some less than that, it's really a luck of a draw type of thing. Just something you have to deal with as the alternator deals with heat cycles, mileage, and age.
The car itself will last much longer than 120k. The powertrain is relatively bulletproof (although, people tend to do have trans issues when mileage starts getting up there if they beat on it/ignore fluid changes), it should easily exceed 200k. There are quite a few people on here in the high 100s/200s at this point.
I changed mine @ 108k miles.
https://www.clublexus.com/forums/is-...-analyzed.html
As long as you keep up on maintenance and replace wear items it will last a long time. You shouldnt have too many issues up to the 275,000 mile mark if you take care of your vehicle. Most likely you will want something newer way sooner than its time to replace the car because it's worren out.
My Lexuses!
I bought a 2010 IS 350 at 77K miles, now at 82 K miles. So far had to spend a bit with only 5000 miles, read break pads, tire replacement due to a thread of 3-4, now was told that the engine oil is leaking. I love driving this car, better than any car I have driven before (Genesis, Avalon, ES350, RX 300). I purchased insurance on it after the last service and they have agreed to pay for the oil leak
I am worried if this car should be a keeper. Did I buy a lemon, is it my driving habits or this is all normal
thanks
from an engine novice
thanks
I'm a Toyota technician. I can tell you from experience that if you take care of your vehicle, the power plant and transmission will hold strong longer than you can imagine. It really isn't uncommon for these vehicles to reach high 200-300k miles. The 2GR platform is utilized in a lot of Toyotas. A lot. They, if cared for, do not die. The transmissions, same story. Soccer moms beat the heck out of the 2GRs in Siennas and Highlanders and can't seem to kill them.
As others have mentioned, there are, of course, items that are considered wear items that will require replacement at some point. Alternators, batteries, water pumps, etc. Suspension is a highly overlooked area. The suspension starts to display symptoms around 200k, maybe less, depending on how you drive, where you live, etc. A friend of mine has a 1998 Land Cruiser with almost 200k miles. He's maintained it well and it still runs like new.
I just bought a 2010 IS350 with 106k miles. I consider it barely broken in.
thanks
thanks
Oil leak if fixed properly, you should be good to go. Where is it leaking from??
Tires the door plate likely says 32 PSI. Run 40 PSI in the front if you do a lot of city stop and go, parking lot action as they can eat the inside of the tread at the edges.
A cure is new Lower Control Arm Bushings (LCAB) from an RC-F and have the tow set to zero. LCAB are $160 total and the car will drive better.
GL - maybe start a new thread with any issues you suspect.
As the title says
My car is a IS 350 2007 has 92k miles, I always take it in for regular maintenance and get done whatever the dealer says. I even still get it waxed every year or two at most. Interior looks great still. I am the only owner of it, bought it in 08 (I think). I only drive it to work which is close to my house now, so I don't even get close to the miles for each service appointment, I do it by date.
A few months ago, my car did die on me for the first time. The alternator went out and killed my battery too. I got those replaced and everything is running good again.
How much more can I safely get out of my car though? I was hoping to maybe reach 120k or higher ?? Maybe 3-4 more years ?? I have no idea.
Anyone else have any ideas for my car? Do others have more miles and are running fine? Any big issues?
Thanks!!
Thanks!!
I have the same situation in that during this whole last winter I drove mostly short trips around town and only 1,000 miles the whole time. One thing I do (much more during good weather) is to drive it just for fun on some 30-40 mile rides every week or so to get the engine up to temperature periodically and make sure the battery is up to normal. I look at those rides as upkeep and preventative maintenance, not an expense.
2013FSport (09-06-22)
For reference, my 2007 IS350 is currently at 197K since I had bought it at 40K, 13 years ago. I've had many wear items replace like any normal car. Transmission and Engine still rocking solid. It does burn a bit of oil 1qt every 5k miles. But that's about the time for oil maintenance anyways. Maintain it with routine maintenance and it should last you until the government force everyone to drive EV car.
Keeping a battery tender helps extend the battery life as well, if not a daily driver. Mine is hooked up every week, because it is not the daily driver. I have quick disconnects so it is convenient and easy to charge. When not in use, I plug it in.
roger13134
ES - 6th Gen (2013-2018)
06-12-17 01:12 PM
Laynie710
09-04-11 06:23 PM
Lamprey
ES - 5th Gen (2007-2012)
22
04-16-10 04:20 PM
