Pulling Fenders
Old 09-19-16, 04:02 PM
Silver09IS
Silver09IS's Avatar
Default Pulling Fenders
Anyone in here pulled their fenders and any pics of it? How much did they charge you? Thanks!
Old 09-20-16, 03:37 PM
knyg
knyg's Avatar
i think you mean rolled. no shop will pull out your fender liners. they can either cut the fenders or they can slowly roll them. anyways, for a shop to work on them and get you more clearance for your wheel set-up, its going to cost about $40 per wheel well. but the lexus 2IS doesnt have much of anything in the front wheel well's fenders to roll/delete. so youll really spend ~$80 for both the rear fenders.
Old 09-21-16, 03:55 PM
Silver09IS
Silver09IS's Avatar
oh man really? I already have them cut I was just wondering if I could have my rears pulled out a little bit cause I'm having to run -4 camber so I can tuck when I air out.
Old 09-21-16, 06:18 PM
trippy
trippy's Avatar
where in socal r u ? if anything hit up FENDER DEFENDER A+++ look up on yelp
Old 09-22-16, 02:16 PM
Gville350
Gville350's Avatar
Technically there is a difference in pulling a fender vs rolling. Rolling is the safer and cleaner route, though I DIY'd pulled my fronts to help with slight rubbing on HARD corners bumps.
Old 09-27-16, 08:05 AM
bob4256
bob4256's Avatar
There are shops that will pull your fenders, those that say they wont do it most likely do not know how to do it properly. And you get a natural pull when you roll fenders so sometimes that will get you enough clearance. If you need more space you may want to consider adding more camber in the rear so you can tuck more.
Old 12-28-16, 04:20 PM
mandipcarz
mandipcarz's Avatar
Old 12-28-16, 05:55 PM
B00M3R
B00M3R's Avatar
I bought my own roller, it wasn't to expensive and now I own it.
This is the one I got, there are cheaper ones but I wanted something I could rely on.
http://www.eastwood.com/ew-fender-roller-w-instruction.htmlfee=7&fep=1286&SRCCODE=PLA00020&product_id=31158&adpos=1o1&creative=83580264780&device=c&matchtype=&network=g&gclid=Cj0KEQiA4o3DBRCJsZqh8vWqt_8BEiQA2Fw0ecwQrd7vrl3PJkBKijdtTYcnZSINDgrbdzFQEU_92TcaAs8g8P8HAQ
Edit: should have watched the video, haha same roller I have and yes make sure you heat the paint or it will chip. Take it slow and it works well.
Fernanhaya
Suspension and Brakes
01-23-12 11:10 AM
sclee00
SC- 1st Gen (1992-2000)
01-04-12 05:50 AM
93sprucesc
07-30-11 05:41 PM
marshun
10-19-07 02:32 AM
play123boi
CL of Southern California
08-09-07 07:16 PM
Quick Reply: Pulling Fenders
