My IS250 cuts off in park
Old 09-20-16, 04:41 PM
CML17
CML17's Avatar
Default My IS250 cuts off in park
i have an 2006 Lexus IS 250 with 163,000 miles on it, today I went to pick up my sister the car cut off I had to get a jump off so I thought it was the battery then I then left school went to pick up my grandmother to take her to her doctors appt I got there I left car running when I came out the car was off, I sat down in it tried to crank wouldn't crank, I went back in building came back out I had left the ignition on in car I started to sit down in car the car starts to turn over by itself I never pressed the start button, so the car finally started in park but acted like it didn't wanna run in park I put in neutral it was fine it didn't cut off only when I put it in park the dash lights go off and car die down and eventually cuts off... Has anyone had this problem before someone please help.
Old 09-21-16, 03:14 AM
Bichon
Super Moderator
Bichon's Avatar
Sounds like a bad alternator.
Old 09-21-16, 03:57 AM
CML17
CML17's Avatar
Default My is250 cuts of in park
It cranks in neutral but I have to forcefully crank in park but keeping my foot on gas and sometimes still dosent work... I did a little more research and the only thing it could be is the park/neutral saftey swich which is located on transmission that swich can actually cause the transmission to go into limp mode which explains a lot.
Old 02-02-17, 08:56 PM
Galeh
Galeh's Avatar
if u are following my forum I'm in the middle of process of changing NSS neutral safety switch,
let me replace it and I'll let u know
Old 02-03-17, 08:14 AM
CML17
CML17's Avatar
Ok will do haven't replaced mine yet it, hasn't been acting up lately
Old 02-08-17, 09:24 AM
Galeh
Galeh's Avatar
I broke my switch during installation because of over tightening
Old 02-08-17, 12:34 PM
jehmin
jehmin's Avatar
What does this NSS neutral safety switch Do?
You should test the Battery and Alternator at any parts shop they will tell you.
Also go to multiple locations because. One person might tell you something wrong. This happened to my before.
I changed the alternator and battery last year. However sometimes When shfiting from drive to reverse my engine will cut out if I let it sit a second without gassing it.
Anyone else have this issue? I think this happend before too before battery and alternator
Old 02-20-17, 06:44 AM
Galeh
Galeh's Avatar
Default Neutral safety switch replaced
My issue has been fixed with replacing the neutral safety switch.$75 for a used one and I replaced it at home in my garage
Old 11-24-20, 11:29 PM
Ham
Ham's Avatar
i know this thread is old. but i have a faulty NSS is it hard to replace. Is there a write up.
lovetheIS
05-20-17 07:20 AM
ExtraZero8
12-08-16 03:10 PM
Aristo94
GS - 1st Gen (1993-1997)
11-26-06 07:52 PM
Quick Reply: My IS250 cuts off in park
