Stock 0-60 on 350 AWD?
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_5168_9744b9dfe57abf67aa557434a6a9bf84c50a3317.jpg)
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_5169_ded94a65fb03d08d8a2de8068a3f5dfd3733a610.jpg)
hey guys I'm new here, just bought a used 2011 Lexus IS 350 AWD.
did a basic 0-60 just video tapped and think I did in 5 seconds?!
will post link to video soon
thanks! I was thinking the same thing and was wondering if anyone got the same results, full tank of gas, 70F dry conditions didn't do launch control
there's no science to what I am about to say, but i had a RWD 350 that I traded for a AWD 350, I did several road tests and was back and forth between them, RWD feels slightly quicker to the point where it is noticeable, but the AWD is very close behind. to get the most out of it, turn off your TRC and VSC, put it in D and normal driving mode..
Did a 0-60 test with my 2011, AWD with cheap Firestone tires on a slight incline in regular drive mode with traction control on. Definitely under 5 seconds! These cars are underrated!!
I had it in Sports mode when I did this run, which holds the revs when going hard. In normal mode it shifts quickly through the gears
You'll have low KCLV so go drive around to get the maximum you can.
https://www.clublexus.com/forums/is-...ml#post2539716
Reset the ECU. Either fuse or - Negative unhooked on battery side. Wait 15 minutes or more, and then reinstall.
Redcastle
10-17-13 07:11 AM
