245/40R19 for front tires??
Old 09-21-16, 09:08 PM
Damian2is
Damian2is's Avatar
Default 245/40R19 for front tires??
Hello, just wondering if any one has ran 245/40r19 in the front, and if so how was the ride(any rubbing).
Old 09-22-16, 09:39 AM
VaderIS250
VaderIS250's Avatar
In for an answer too. Just got these for my 19's and will be mounting them this weekend.
Old 09-22-16, 01:32 PM
SeanO
SeanO's Avatar
Is the car lowered at all? AWD or RWD?
Old 09-22-16, 02:13 PM
Gville350
Gville350's Avatar
Offset of the front wheels?
Old 09-22-16, 04:01 PM
Damian2is
Damian2is's Avatar
The car is a Rwd, and it is not lowered yet but not sure if Ill be able to with it being 19s in front and 20s in the rear
Old 09-28-16, 12:20 AM
Ling2IS
Ling2IS's Avatar
Post for future reference.
Old 09-29-16, 10:16 PM
Koolsport
Koolsport's Avatar
Haven't run that size but I think it will rub even at stock height, being that stock size for the Is 350 is 225/40/18.
Being the number 40 represents 40% in height of the 245 width. So wider and taller...than stock, lowering the height any amount I believe would definitely cause it to rub.
Old 10-01-16, 07:11 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
I run 245/40R17 without issue, but a 245/40R19 is going to rub. It's just too tall.
Jeff
Old 10-03-16, 09:10 AM
VaderIS250
VaderIS250's Avatar
Just got mine mounted, and they do rub a little in the front if you're lowered. The rub on the wheels wheels mainly U-Turns but that's about it for me.
Old 10-24-16, 10:11 PM
JohnMorgan
JohnMorgan's Avatar
I've been running a 245/40/19 square for a while, I like the larger tirewall but it does rub (I'm on coils) and might look funny. Stick with a 35/30 setup depending on if you're running staggered and what widths too.
Old 10-25-16, 01:02 AM
See5
See5's Avatar
One of the drawbacks of the IS is the small wheel clearance. I had 235/40R 18 Which used to rub in U turns ! My car is not lowered and I returned back to 225/40R18. Even the 40 profile is too low for the bad roads in my area.
Old 10-26-16, 12:49 PM
RussZTT
RussZTT's Avatar
I run them and very happy. I purchased my car already lowered with aftermarket wheels. I put that size all the way around (AWD) and I love the way they look. They do rub just a tad when I turn sharp on the fender liner but not bad.
Old 10-27-16, 08:11 PM
Activated
Activated's Avatar
i have 245/35/19s on the front, and they rubbed a tiny bit, but all i had to do was push this tiny plastic piece in the wheel well away from the tire. lowered on h&r springs.
Parsa
05-01-17 07:36 PM
Phresh2010
02-04-15 07:20 PM
Texas2009
09-08-11 09:51 AM
Dj_AmtraX
11-08-06 10:27 AM
Joe C
Wheels, Tires & Brakes Forum
11-01-06 09:16 AM
Quick Reply: 245/40R19 for front tires??
