Oil leak help (pics)
I've never been in for a warrant repair/fix, so I could be wrong; but doesn't a factory powertrain warranty cover a leak from all of the major components (engine/trans/diff)?
Drivers side has the Alternator to work around.
Top right...
Not mine obviously....
Just noticed a small amount of oil from the same area while doing an oil change on my ‘07 is350, around the banjo bolt. I loosened it and retightened it but would like to confirm the part # for the gasket o-rings.
Is it 90430-16016 ? If so, is that just the piece pictures or also 2 copper or similar washers?
Does 94030-16016 contain the U shaped bolt gasket AND 2 separate washers?
So to do both sides of the car you need only two 94030-16016?
Hey, I'm having the same on my 2006 GS300. Is it an easy job to dyi replace those gaskets? Do I have to pay attention to something else, besides draining oil and just removing the bolts?
Understand this t be older post however, interested in confirming correct part numbers and amount of each needed shown below is correct, just to have should issue be encountered;
9043016016 - Gasket / Banjo washer / oil line (U shaped / Need 2 for both lines)
90430-16012 - Engine oil cooler line gasket / washer (Need 4 for both lines)
9040116043 - banjo bolt / union for oil line (need1)
1579731010 - bolt / oil check valve (need 1)
