I would google the codes or maybe someone around here can look them up.
If your injector circuit is stuck open it is pouring fuel into that cylinder all the time. Hence you're using more fuel. You will ruin your oxygen sensors on that bank and also could ruin your Catalytic Convertor if you don't have this checked.
The VSC and Traction Control light is just the ECU going into safety mode and turning it off because it senses your engine in trouble.
Injectors can stick open because you could have a short in that wire (Cylinder 1). You may try to wiggle the wiring harness from that injector to see if you can move it just enough to stop the short as a temporary thing before you get it fixed. Your trouble code lights will go off if you are successful.
Get this fixed, driving it will cause some expensive repairs by ruining your O2 Sensors and eventually your Cat.
