Dash Warning Lights Worrying Me
Old 10-11-16, 04:26 PM
Ken167
Ken167's Avatar
Default Dash Warning Lights Worrying Me
In the last week the airbag light and CEL came on. Code P0174--bank 2 run lean condition. I researched the forum on both--found out the airbag light could be the pin connector. Lexus dealer said could be that or general problem with any part of the system. P0174 could be dirty or bad injector. Both codes were reset.
Anytime a warning light comes on I see lots of $$$$$ signs. Will monitor the situation!
Old 10-11-16, 04:35 PM
MAizz
MAizz's Avatar
My 06 had the airbag light issue, if I remember correctly it was the wiring harness was tripping the system to show an error but it did not effect the actual system.. I may have remembered that wrong but at the time I just removed the cluster and covered the light as a solution. Again, my memory may be wrong but I believe that even if you fix the wiring, the problem can still arise which is why I went that route.
Old 10-11-16, 07:26 PM
Ken167
Ken167's Avatar
CEL on again--going to get it checked again tomorrow--if same run lean code then will have MAS cleaned and run thru bottle of Sea Foam. I don't know what else to do!
Old 10-12-16, 04:28 AM
HankMoody
HankMoody's Avatar
You should be able to tell which cyl is "lean" then replace that injector, which is more than likely your problem.
Old 10-13-16, 03:18 PM
Ken167
Ken167's Avatar
CEL went off by itself. Hmmm not sure what happened!
Old 10-15-16, 06:24 AM
The350Girl
The350Girl's Avatar
code p0174 and p0171 system too leaned = vacuum hose leak, Ken, 1st throw some good Fuel injector in your gas tank, replace your air filter 2nd clean your maf sensor check all wiring and hoses. reset the code again, if 0174 don't come back in 200 miles then you are good.
You are getting p0174 alone i'm pretty sure one of the hose around your air filter box is lose but then you already there so just do it all at once.
Old 10-15-16, 11:40 AM
Ken167
Ken167's Avatar
Thanks. Yes I ran thru 2 bottles of B12 cleaner and CEL went off. Air filter is clean. If CEL comes on again will check hoses and MAF
vbabu2
04-08-24 05:23 AM
O. L. T.
Performance & Maintenance
45
11-29-21 01:10 PM
PhilTyler
RX - 1st Gen (1999-2003)
06-21-17 09:04 AM
robertoyou
03-08-12 05:25 PM
acc
08-08-07 10:49 PM
Quick Reply: Dash Warning Lights Worrying Me
