Help needed shifting issues
ok so my 07 is350 is having a few issues. The check engine light & check vsc just came on and I scanned the car P0172 & 0175 came up.
banks 1&2 are running to rich so I change the filter and plugs reset the code and it was gone for about 2 days now its back.
I also have a problem with the car not moving when I step on the gas until I hit about 4000 rpm the car starts to roll but I have to really gas it to get it going which isn't healthy for the car
if anyone had these problems I would greatly appreciate some advice or a solution
The MAF sensor is really the only thing that can cause those long term rich codes. I had the same codes and examined the MAF, which looked perfectly brand new and sparkling clean, I hosed it down with MAF cleaner and saw no improvement, the codes just kept coming back. Finally I replaced the expensive sensor and all was well.
oyeitsdean
04-17-17 07:33 PM
