is250 2008 engine noise or its a regular noise ?
hey guys
i need some help here im new with lexus car and i need some help with this
the engine is making some noise but i do not know if that noise is normal for the is250
before i take it to the lexus dealer to check it out
i would like to see what you guys say
here the vid of the engine, you can hear the noise better at the end of the video
Sounds like bearing rattle (for example in the alternator) but the video is too short to really tell plus the cooling fans were running half the time.
Sounds like the water pump bearing is eating itself. If you'd like to find out definitively if it is the water pump, remove the accessory belt, and turn the WP pulley by hand. It should be smooth and have no in-and-out play AND no side-to-side play. With the right tools, it'll take 5 minutes to remove the belt and re-attach.
timboat
10-17-17 08:32 AM
