High beam/DRL Fuse location
Hi, I've been searching the whole forum and the manual for an answer, hopefully somebody will help.
My high beam/DRL driver side bulb went out, so I bought one and replaced it but it doesn't work.
I'm assuming is a faulty fuse but I can't find it anywhere. I found the right and left HID low beam fuse but luck with the DRL.
Does anybody know what could be the problem or where is this fuse.?
Thank you.
2008 is250
Thank you.
2008 is250
