PS light on and no power steering any help
i took off the battery terminals becuase i was changing spark and when i put the terminals back on my PS is on and i have no powersteering 2006 lexus is350,last time i had this issues is when the alternator went out but there was no PS light and when i change the alternator and every thing worked and all of a sudden the PS went out any advice would be helpful
Jubril (04-27-22)
I'm to lazy to look in the owners manual but you may have to reset it/re calibrate it. Turn the car into the on position and turn the wheel all the way to the right as far as it goes. Then turn it to the left as far as it goes. This might reset it.
Now I don't know if this is how it works for he IS350 but on some other vehicle models this is how it works.
Check your owners manual to see if it has anything in it about this.
You might want to check your fuses under drivers side dash. Not sure which one it is but maybe LH-IG or FR S/HTR LH. I lost power steering when I pulled one of these fuses out.
They have them for different models and years and they come with a 1 year warranty.
I got one and my power steering is fixed now. First one was no good but they sent me a second one right away under warranty.
You can buy a salvage ECU on https://www.benzeenautoparts.com/
O1GS43O
10-24-10 10:40 AM
SC4Hundred
Performance & Maintenance
17
02-10-05 02:49 AM
