Is my transmission going out?
Hey guys, so I took my car downtown earlier today when I went to get a haircut, and upon leaving I noticed something odd. On the cluster where it says PRND and S , the little green backlight wasn't turning on. Also upon putting the car into Drive, it felt as if the transmission Jerked kind of hard. I was worried and tried again to see if it goes away but nope , every time I go into Drive the car Jerks. Also my car no longer tells me what gear I'm in, won't let me use manual mode (it only lights up the "S" for a second then goes dark again) and even my turn signals don't function for some odd reason. Ever stranger is that the hazards (which use the signals ) work just fine ? ? ?
Upon getting home I didn't notice anything different about the transmission feel, it's feels perfectly normal as far as I can tell. All gears feel like they are working okay and there was no slip or grind as far as I can tell over a 8 mile drive. Only issue is putting it into drive... Where it once again jerks.
I also got the check engine light for the first time in my 2 years of ownership Any clue what this can be? My mechanic buddy said it might be something electrical like a sensor but that was just an over the phone "diagnosis " . Any help guys ?? I'm super stressed about this. Thanks
Makes sense since every single electrical component in the car was going haywire just a second ago. Power steering went out , gage cluster soon followed, every single error light lit up. Clock went out, car started bogging , screen went black etc. . . Smh .
Just did Code P0705 . Transmission Range Sensor in circuit A.
i had a similar issue when im alternator went out but only difference is mine throw different codes and when i replace my alternator everything was fine,
OG Member
Since you mentioned that your power steering was going out as well as the gauge cluster, I think your alternator might be dying.
Using a voltmeter, try checking your battery voltage while the car is running to see if you're within normal parameters (Voltage should be in the mid-13s to low 14s). Also check to see if you have any corrosion buildup around the battery terminals.
No I didn't erase it (although I should have). I was at my friend's house when we checked it, but I'll try and have him come by to try that too to see what happens. When I got the car home last night it wouldn't turn on anymore and only barely made it. Similar to where the alternator on my dad's 91' F150 went out. I'll have to look Into this a bit more. Hoping for the best, wish me luck !
OG Member
Statistically, our alternators have a 8-10 year lifespan so it sounds like you're right at that point with your IS350.
You're right about the trans having acted up like it did being really weird, but the other symptoms definitely point towards your alternator on its way out. If you've got at least 3yrs or more your battery, you might want to consider getting a new battery at the same time too.
Battery or Alternator dies give you random check engine codes, no worry just replace bat and alt you'll be ok, my IS thrown randoms codes when battery completely dead, i remember batter was 0% power when i replace it, it caused some fuse burnt too i just post for help in other thread, Lexus is very sensitive vehicle but definitely easy to self-fix unlike Merc BMW or Audi. i like to do man things like my mom
Oh man I am SUPER relieved to be reading all your replies! I went ahead and purchased an alternator today and will go ahead and install it over the weekend , hopefully that really was the problem after all.
Also in regards to my battery it's only a year old so I'm hoping it's still good. I have it disconnected right now too just to be a little more safe. Thanks for all your input guys!!! I'll keep you posted !
I have the same issue. If the car sits for more than a few hours, the transmission will require that I rev the engine (while in Drive) a bit before engaging (also in Reverse). Once engaged, it runs perfectly normal. It's been that way for months. I did the fluid change and didn't see much improvement. I replaced the alternator months ago because I am at a higher mileage and it just went out. Not sure if the transmission issue started at the same time.. but I'm pretty sure these are separate situations. Mine is a GS300 though.
