What size socket or wrench do I need, oil change
Old 11-02-16, 06:44 PM
P128sniper
P128sniper's Avatar
Default What size socket or wrench do I need, oil change
When changing oil there is a special Toyota round tool you can buy from autozone that's really cheap and fits onto the oil filter to remove it. Anyone know what size socket or wrench I need that fits onto the Toyota tool? Wondering what kind of socket wrench set I woukd need to get to do my own oil changes, I know I need 10mm and 14mm but not sure of size for the Toyota tool
Old 11-02-16, 06:50 PM
BlckGhst
BlckGhst's Avatar
Dont know about the Auto Zone tool, but I have the Blue Point one, and its a 15/16"
Old 11-02-16, 07:38 PM
Aspect
Aspect's Avatar
Any 1/2 inch drive socket wrench should fit into the Oil Filter Socket tool.
Old 11-03-16, 10:53 AM
Tungstn-IS
Tungstn-IS's Avatar
The one I use from autozone uses 7/8" socket. Not sure if that's the same one you have though.
Old 11-03-16, 12:00 PM
flowrider
flowrider's Avatar
Received 1,930 Likes on 1,361 Posts
Why not ask the person behind the counter at AutoZone?
Lou
Old 11-03-16, 01:25 PM
P128sniper
P128sniper's Avatar
Lou
Thank for your useful input. my ocd kicks in and I like to have everything figured out before I get into any project.
Old 11-04-16, 12:22 PM
ponteley
ponteley's Avatar
Mine is 15/16 for 1/2 socket from Advance Auto. It was like $4.99
Old 11-04-16, 06:22 PM
Ling2IS
Ling2IS's Avatar
There's a special filter wrench you absolutely need to remove the housing for the ISx50, especially if the car's had the oil changed by a shop in the past who most likely over tightened it. It's called TOY640. Runs about $20
Old 11-04-16, 07:57 PM
P128sniper
P128sniper's Avatar
Originally Posted by Ling2IS
There's a special filter wrench you absolutely need to remove the housing for the ISx50, especially if the car's had the oil changed by a shop in the past who most likely over tightened them. It's called TOY640. Runs about $20
I know, my question was what size wrench do I need to turn this special filter tool
Old 11-04-16, 10:11 PM
Ling2IS
Ling2IS's Avatar
My bad haha. If I remember correctly, it was a 24mm socket
Old 11-04-16, 10:34 PM
flowrider
flowrider's Avatar
Ok - Here's mine. As you can see I bolted a socket to the tool. That socket is, as has been said above, 15/16"
Lou
Attached Thumbnails What size socket or wrench do I need,  oil change-oil-wrench.jpg
Old 11-05-16, 06:44 AM
Bichon
Super Moderator
Bichon's Avatar
If you don't have a 15/16 socket in your toolbox, you can also use a crescent (adjustable) wrench.
2istype
12-02-17 05:35 PM
Mdantuma1
07-15-17 02:05 AM
sapd911
ES - 6th Gen (2013-2018)
05-13-15 04:22 PM
UncleRay
NELOC
22
03-25-08 04:45 PM
palinorus
07-24-02 04:55 AM
Quick Reply: What size socket or wrench do I need, oil change
