Bad battery or starter
Old 11-03-16 | 10:31 AM
sscelzi's Avatar
sscelzi
Default Bad battery or starter
So yesterday I tried starting my car, this was after a very cold day and not moving my car, it made a clicking sound on three attempts. on the fourth my car started. so before driving to work I let it warm up about 10 mins. then last night and this morning my car started but started slow. I tried calling my mechanic who I couldnt get ahold of. so I just took my car to the local walmart to have battery tested. they said battery was fine but just needed a charge so it could be my starter or alternator. well I always need second opinions, so I went to autozone to have all three tested. they said my battery is bad and needs to be replaced. my battery is about 4 to 5 years old so I probably do need to replace battery but the clicking sound makes me worry about the starter. I have a 2007 IS250. any suggestions?
Old 11-03-16 | 10:38 AM
BlckGhst's Avatar
BlckGhst
Start with the battery. The clicking may be due to that
Old 11-03-16 | 10:40 AM
sscelzi's Avatar
sscelzi
Yeah I think that's the best way to start...not to mention cheaper.
Old 11-03-16 | 11:57 AM
Tungstn-IS's Avatar
Tungstn-IS
Sounds like a weak battery. With it being 4-5 years old, it's about time to replace it anyway.
Old 11-03-16 | 08:12 PM
ezbmr's Avatar
ezbmr
Have AAA check out your battery, if it goes to 14, then starter.
Old 11-17-16 | 08:15 AM
FALI's Avatar
FALI
Default Get your camshaft checked out
I had the clicking noise problem too and the Lexus dealer found an issue with the cam shaft and replaced it.
Old 11-17-16 | 09:08 AM
getafewliv's Avatar
getafewliv
Or just buy a cheap voltmeter and do it yourself...
Or since the battery is 4-5 years old anyways, it's not not exactly expensive preventative maintenance.
Old 11-17-16 | 09:09 AM
getafewliv's Avatar
getafewliv
I think you are talking about a completely different issue.
Old 11-17-16 | 06:48 PM
Gville350's Avatar
Gville350
How many CCAs was the current battery producing?
Old 11-28-16 | 12:46 PM
zachk86's Avatar
zachk86
If it clicks, it is most likely the battery. If you hear a whirring but no clicks and the lights/radio/etc are perfectly fine when starting, it is most likely the starter. My buddy had this problem and it ended up being the starter but yours sounds like a battery.
Old 11-28-16 | 12:51 PM
4TehNguyen's Avatar
4TehNguyen
battery is 4-5 years old, just replace it. Why do people jump to the conclusion its the starter when the chance of it being the battery is far greater...and the battery tested bad at autozone. Ive replaced tons of batteries but I've never replaced a starter.
9000revs
04-26-17 01:23 AM
NSXGuy
IS F (2008-2014)
32
04-14-16 02:50 PM
thinkin
06-03-11 07:13 AM
n0bodi
10-17-10 01:01 PM
RedPhoenix
Performance & Maintenance
18
03-30-08 11:52 PM
