Knocking sound while turning on wet
Old 11-17-16, 10:42 PM
ArtIS
ArtIS's Avatar
Default Knocking sound while turning on wet
Hi!
in my 2009 IS250 AWD I've observed a weird knocking/rumbling sound of front wheels. IT comes up when I turn on a wet surface (asphalt or paving stone).
I have proper tire size and pressure, regularly changed steering fluid so I'm worried about that.
I drove a service once and they told me that due to the AWD system, the wheels bend over differently and that where the sound cames from. I don't think such story can match Lexus but mabe somebody can help.
Regards,
Arthur
Old 11-18-16, 02:15 PM
Gville350
Gville350's Avatar
Worn/bad CV joints in your half shafts?
Old 11-18-16, 03:32 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Sounds like your CV axle is wearing out. It can knock and still last a good while.
Old 11-18-16, 03:39 PM
tomiv9
tomiv9's Avatar
I have the same car. Haven't had those symptoms but the dealer indicated my cv boots / axle was leaking. it was minor so just recommended I keep an eye on it. they said if I hear clicking def get it checked out. so that could be prob. Def get axles looked at
Old 11-19-16, 01:00 AM
ArtIS
ArtIS's Avatar
Thank you all
on the 24th of November I'm visiting my service guy and tell him to look at the CV's.
Regards,
Arthur
Old 10-10-17, 09:59 AM
rizwansial
rizwansial's Avatar
Default IS 250 AWD 2007 Steering issue
Hi guys I am new here. I bought IS 250 AWD 2007 few months back from UAE auction. It have very hard steering like no power there. Checked with mechanic and suggested to replace steering rack. I bought from old spare parts and replaced it. But issue still there and no clue what is exact problem. Any suggestion
A​​​​​​nother mechanic suggest to check steering control computer as May be faulty?
Old 10-10-17, 10:10 AM
ArtIS
ArtIS's Avatar
Hi
do you have the steering fluid? Maybe a leak of lack of it...?
Old 10-10-17, 10:12 AM
rizwansial
rizwansial's Avatar
Originally Posted by ArtIS
Hi
no it's Electric power steering
Old 10-10-17, 11:26 AM
ArtIS
ArtIS's Avatar
Sure? It totally doesn't act like. Mine works tough since 2013
Old 10-11-17, 05:43 AM
jr4div2
jr4div2's Avatar
Yes. It is electric driven by motors. If it's stiff, you should have that checked out.
xillaphl
09-19-18 07:45 AM
RussZTT
10-10-16 07:33 AM
cura1829
01-24-15 05:56 PM
dbs600
12-07-13 09:29 PM
reyoasian
06-24-10 09:47 PM
Quick Reply: Knocking sound while turning on wet
