VIPMOTOZ IS-F Headlight Install
Old 11-24-16, 08:18 AM
2GRFE
2GRFE's Avatar
Default VIPMOTOZ IS-F Headlight Install
So there was a thread that stated no one tried the VIPMOTOZ headlight from ebay on the ISF.
Install was very easy, although the ISF I worked with had suffered front damage before so had to spend more time mounting the lights in place.
Attached Thumbnails VIPMOTOZ IS-F Headlight Install-isf-headlight.jpg   VIPMOTOZ IS-F Headlight Install-isf-headlight-2.jpg
Old 11-24-16, 11:13 AM
IamLexus
IamLexus's Avatar
Just installed mine on my IS250, did you install LED DRL (highbeam) or HID KIT for your lowbeam?
Old 11-24-16, 12:06 PM
P128sniper
P128sniper's Avatar
Can u guys give me more info on these, I have the oem halogen ones, if I buy these ebay ones what do they come with? Do they come with any bulbs, does the drl led stripe work without doing anything special?
Old 11-24-16, 03:48 PM
IamLexus
IamLexus's Avatar
I bought the eBay one, it comes with regular bulb for everything. The stripe led only lights up when your lowbeam is on or city light (first switch). Its all plug and play - They even give you a hole where you can drill to plug a hid kit for the low beam. If you are deciding to put a led bulb for your DRL/Highbeam you may need a decoder if its higher than 12v.
Old 11-24-16, 08:46 PM
MikeyK02
MikeyK02's Avatar
For the price and quality
I loved upgrading my front end to these
Old 11-24-16, 10:12 PM
P128sniper
P128sniper's Avatar
So the led stripe isn't the drl, it has another bulb for drl? Any way to make the led stripe the drl
Old 11-24-16, 10:17 PM
IamLexus
IamLexus's Avatar
You can, you need a 10amp circuit holder, the tutorial will tell you
go to 3:00
Old 11-24-16, 11:14 PM
5nX37
5nX37's Avatar
You can, you need a 10amp circuit holder, the tutorial will tell you https://www.youtube.com/watch?v=P9MmL1cj01Y go to 3:00
So, with that, do you or anyone know if the hi beam/drl will also remain on simultaneously with the LED strip or LED strip by itself on DRL only?
Old 11-25-16, 09:31 AM
whitebeast
whitebeast's Avatar
You got to disable drl first.
Old 11-25-16, 01:35 PM
IamLexus
IamLexus's Avatar
Doesn't look bad if you have led in your DRL
Old 11-25-16, 10:00 PM
whitebeast
whitebeast's Avatar
We are talking about the NONE LED DRL - high bean run at 50%.
Old 08-13-18, 04:26 PM
goto35
goto35's Avatar
Doesn't look bad if you have led in your DRL https://www.youtube.com/watch?v=eDCzj9N1U9s
question gonna buy their hid kit. what led bulb works for the drl portion?
Old 11-17-18, 12:57 PM
Pfons250
Pfons250's Avatar
I just installed this as well everything is working but the led drl? Any help would be appreciated!!
Old 11-18-18, 02:59 PM
DallasLex
DallasLex's Avatar
May be use an Add-a-Fuse to an ACC connection directly to the lights, so they come on when the car is on.
https://www.amazon.com/s/?ie=UTF8&keywords=add-a-fuse&tag=googhydr-20&index=aps&hvadid=241929676442&hvpos=1t1&hvnetw=g&hvrand=8777277660144092911&hvpone=&hvptwo=&hvqmt=e&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9026838&hvtargid=aud-562066800653:kwd-11269305925&ref=pd_sl_80q13hzmzg_e https://www.amazon.com/s/?ie=UTF8&keywords=add-a-fuse&tag=googhydr-20&index=aps&hvadid=241929676442&hvpos=1t1&hvnetw=g&hvrand=8777277660144092911&hvpone=&hvptwo=&hvqmt=e&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9026838&hvtargid=aud-562066800653:kwd-11269305925&ref=pd_sl_80q13hzmzg_e
whitebeast
11-25-15 08:34 PM
hksnlper
IS F (2008-2014)
03-12-15 08:02 AM
jooksingja
Canada
11-14-14 12:22 PM
cm09578
09-04-13 10:13 PM
CCLSVTF
07-13-13 11:23 AM
Quick Reply: VIPMOTOZ IS-F Headlight Install
