Help! Wheels rubbing.
Hey IS FAM,
just recently installed some new aftermarket wheels on my is and they are rubbing bad. Every time I leap over bumps or drive over train tracks it rubs (rear wheels). If I reverse out (turning my steering wheel) my front wheels rubs as well. Any suggestions would do. Thanks before hand.
Set up:
Front - 18x9.75 +20 offset 225/40/18
rear - 18x9.75 +20 offset 255/40/18
Set up:
Your already stretching tires as much as you can I'd say - You'll more then likely have to do some fender work to get it to not rub at all
The front it could just be in the inside fender liner that your rubbing on which has been solved with a heat gun for some
As mentioned above though those are very aggressive offsets especially with 9.75" wide rim upfront
thanks for your input. I've got my fenders rolled already. But it's still rubbing. You think a camber setup will help?
I see. You'll need some work up front. Since you're already rolled, you'll need to shave and do bumper tab relocation up front. Here's a link: scroll down and you'll see pics of a 2is (http://www.wrongfitmentcrew.com/foru...ods-quot/page3)
I took some pics during my process but too lazy to post it up... lol
As for the rear, tire stretch or camber arm shall do. I don't think you'll need to pull...Correct me if I'm wrong!![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Hope this helps.
Hope this helps.
Hope this helps.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Hope this helps.
Get Megan Racing that's what I have on. Just remember though, you might need to buy control arms as well cause I had to get both to clear but then again you might not. I just needed it to air down all the way.
