Engine ECU removal DIY
Keeping it Real
Remove the LH fender apron cover (several clips). Underneath you will find the fuse box and engine computer box mounted beside it. Remove the 3 10mm bolts and pull the cover on the box off. Use a pick or similar to remove the junction block mounted inside the case, once it is removed you can pull upward on the two harnesses coming into the box and unplug the connectors. Once the connectors are removed, there are 2 10mm holding the ECU in place, remove them and lift it out.
Jeff
Jeff
CoRx450h (06-17-22)
here i just did it in about 30 mins.. you could do it for less but i took pictures and was texting my gf. lol
but anyway!
first of all disconnect your battery!! very important
then this is the box that holds the ECU
remove 3 bolts as shown
start pulling everything you can pull! be gentle
yeah you need to take this out because its in the way
so insert a small screwdriver or something similar
pull it towards you and pull the blue thing at the same time
same for this one too!
then, pull all that 6 plugs
then you take the 2 bolts that hold the ecu
TADA! lol
but anyway!
TADA! lol
If you're trying to pull it out after taking the harnesses off, make sure you're moving that harness near the headlight out of the way (pull up on the rubber to remove it from its seated position). I just did my alternator the other day and left everything intact, the ecu had to be knocked loose from not moving for 11 years, but otherwise, pulling up on the junction box, then the rubber harnesses, and the ECU should have have lifted enough to give it enough room to get out of the box.
changing ECU on 2006 GS300
at 115,000 miles, started hard shifting first 2 gears both accelerating and decelerating. Took it to my mechanic I have used for 25 years for various vehicles, and one of their specialties is rebuilding transmissions, They dropped the transmission pan, no metal filings, everything looked mechanically. No transmission related codes stored. Then i did exactly as Metaleckz described here. I am not that mechanical, but was able to gently remove all the electronic plug-in, and remove the ECU. Sent it to MAS Electronics in Buford, GA on a Monday afternoon, they received it Wed. around 10 am, did their work, they put it back into the Fed-x system on Thursday AM, and I received it in Houston at 11:30 AM on Saturday. Total cost including Fed-x was $161. Put it back it -voila! Fixed the problem and car and transmission run perfectly.Almost surreal to me that the fix was that simple.
playa3 (09-04-21)
About the white box next to the ecu
Would like to ask, how to off the white box without damage the plastic next to the ecu due i need to remove the ecu housing to replace the alternator, thanks. 😊
Have a look here to get ideas.
https://www.clublexus.com/forums/is-...removal-3.html
FATHIM (05-11-21)
FATHIM (05-13-21)
When the part numbers match is it compatible? I just changed mine and am getting weird P0000 codes and an AWD C code.(swapped the IC900 chip)
if I would’ve known that I could get all wheel drive on my 2001 GS 300 just by changing the ECU I would’ve done it years ago. Lol.
