Scosche Lexus IS Series Dash Kit Real
#31
Where is the volume control from the HVAC? It's not visible in the pictures, and it doesn't appear there is an alternative screen selection. Or is that what the SET button is for?
#32
Does this Scosche unit have all the adapters/wire harness to install an off-the-market head unit? Or will you need the beat sonic wire harness?
I currently have the beat sonic wire harness along with a pioneer 4200nex head unit and I love it. I like this Scosche unit because it puts the radio up a little higher. I would sell my beat sonic and give this a try just because of the radio being up a little higher. But, selling the beat sonic might take a while.
#33
It should come with everything. That's the entire purpose of the kit, is to add an aftermarket 2din headhunt to your car.
#35
Good to know. I have my BeatSonic waiting to be installed. Just sorting out my ABS sensor issue first.
BTW, do you know off hand what size bullet connectors are needed for the Beatsonic harness? I thought that was rather petty that they give a harness with those connectors installed, but don't include a matching set to install on the aftermarket headhunt harness.
#36
Yes, once you hit the SET button it will open up a bunch of options. The volume for the factory amp is one of them.
#37
#38
The scosche unit is very similar to the beat sonic harness because it comes with all the proper wire you would require to hook up an off the market deck. But the scosche unit also gives you the option not only to hook up a double din unit but u could also install a single din unit. The main difference between both are that scosche comes with a fitting dash kit and will require you take take out the oem unit as a whole. With the beat sonic I believe you have to keep a part of the oem unit for it to work together. If that makes any sense.
#39
#40
This guy is building me a Nav to Non-Nav wiring harness. This will allow me to switch over two a double din radio using the Scosche LS2151B dash kit.
http://www.ebay.com/itm/LEXUS-IS250-...-/251052866099
http://www.scosche.com/ls2151b
#41
#43
Not true, you can install the kit with a car equipped with a factory nav. I believe the bracket would be a bit different but the option is there. You don't need that harness from eBay.
#44
#45
