Rear Wheel Bearing - How to seat aluminum axle dust cover
Just replace one wheel rear wheel bearing, and i noticed during installation, i couldn't properly seat the round aluminum dust cover on the axle. The cover also has a small opening for the abs sensor. When putting the wheel bearing back in place, the cover kinda just wobble about. Is the cover suppose to seat itself once you torque down the axle nut?
Also, have a light now for the Brake and VSC. I am assuming the ABS sensor got moved around. Also, where is the reluctor ring for the ABS, on the axle? i didnt notice any "gears or teeths" surrounding the axle.
As for installing the shield, Its likely damaged and can not be installed. That said, it needs pressed on from the inside.. Not easy to do w the axle in there.
This shield?
lexuseng
04-27-24 02:56 PM
