PCV replacement on my IS350
While I had the wire loom loose on the drivers side after replacing the spark plugs I decided to replace the PCV valve. By the way, the PCV valve takes a 19mm wrench.
![Name: IMG_20161228_143624046%20-%20Copy_zpsbhiiuu2m.jpg
Size: 168.5 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/416449d1501232326-pcv-replacement-on-my-is350-img_20161228_143624046-20-20copy_zpsbhiiuu2m.jpg)
I removed this bolt and it's bracket to give myself just a little more room when working back there as well as loosening the zip tie catches all along the wire loom when doing the spark plugs. However I was having a heck of a time getting any wrench back there (I don't have stubbies) let alone any leverage to turn the PCV.
![Name: IMG_20161228_143632097%20-%20Copy_zpscloeckxx.jpg
Size: 153.3 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/416450d1501232326-pcv-replacement-on-my-is350-img_20161228_143632097-20-20copy_zpscloeckxx.jpg)
Then I remembered my daughter had bought me some crow foot wrenches last year for Christmas and I had completely forgot about them. After digging through all my junk I found them. Below are the Harbor Freight specials that I used which made removing the PCV so much easier. I found that my PCV was pretty sticky even at 66,124 miles so I'm glad I replaced it.
After plugs and PCV the car feels peppy again.
![Name: IMG_20161228_145105780%20-%20Copy_zpsfc5us2kf.jpg
Size: 218.2 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/416451d1501232326-pcv-replacement-on-my-is350-img_20161228_145105780-20-20copy_zpsfc5us2kf.jpg)
Correct. 19mm crow foot, plus long extension, unscrew and replace. Done. You may not even need to remove the small bracket like I did but I had already done it when I was trying to use a normal wrench. I did try a few of my thin wall sockets but the intake manifold is just to close to the PCV. And I did try a 19mm Craftsman Max Axess socket and it did fit but I couldn't get the wrench on it, again due to the intake manifold. The crow foot makes removing the PCV pretty easy.
You can manipulate a regular open end wrench in there with a lot of elbow grease and swearing. But you had the right idea, a Crow Foot is the way to go for sure.
At 235,000km, mine was still fine. I pulled it out because I have been seeing some oil consumption, about 1 later every couple thousand KM. Cleaned it with some brake clean just because it was out, but it felt fine.
Just replaced mine for the second time yesterday. Removed the same bracket to gain enough access to use my box end wrench. Though this PCV had ~50k miles on it, the thing rattled around quite easily and probably was good for another 50k. But for <$10, why not! Also did new plug too!
Thank you Soledad, All. I have a 2006 IS250 sucking oil now (have to refill 1 liter approx for every 1000 kms. Would this be the right tools?
19mm crow foot,
6 x 3/8 in. dr Locking Extension Bar
3/8 in. dr x 15 in. Ratcheting Breaker Bar
My mechanic says "this PCV need not be replaced", "it's hard to access... bla bla bla" so doin it myself.
Thanks,
Ed
19mm crow foot,
Thanks,
Ed
Drawde (07-19-17)
Ok, after 1000 kms, the PCV valve replacement appear to have helped improve gas consumption, now at 10.8 litres per 100 km from 12-13 liters per 100 kms. Oil consumption was the same - still had to top-up engine oil about a litre ++.
mabmab1993
02-26-12 06:54 AM
