Touchscreen not working, climate control question
Old 01-04-17, 09:39 PM
pmnuon79
pmnuon79's Avatar
Default Touchscreen not working, climate control question
My AC is stuck ON, green light under "AC" on my screen is always on. Any way to turn off the ac and get my heat going? I can manually adjust the temperature but my heat only works as the car is in motion, as soon as I stop, say at a red light, the warm air will gradually turn cold. But then as soon as I start moving again, thirty sec later it starts blowing warm air again. Unsure if there's another issue, but other cars I've been in, even with the ac mode on and the heat on, it normally stays warm or hot whether the car is in motion or idle. Thanks in advance
Old 01-05-17, 08:37 PM
nosurprise
nosurprise's Avatar
The AC can be ON, and it should still be blowing warm air. It's probably another issue causing the cold air.
TexLexSC
GX - 1st Gen (2003-2009)
07-01-23 07:47 AM
UncleRico
06-21-19 04:26 PM
virtual
ES - 6th Gen (2013-2018)
27
11-19-15 07:54 PM
toyofreak
Performance & Maintenance
16
06-01-10 11:59 AM
edwinbong
10-20-09 09:49 PM
Quick Reply: Touchscreen not working, climate control question
