head light
Old 01-15-17, 12:43 AM
LC_Ryan
LC_Ryan's Avatar
Default head light
I really should know the answer to this question but I don't. I have a 07 IS250 w/ factory HIDs and AFS. I understand that replacing it with non OEM I lose the AFS. If I did replace the headlight, could I replace it with an aftermarket non HID? Where I could replace the headlight and get a ballast separately for it. Just been through two sets of headlights where ballast have gone and I'm tired of the work involved, especially in the cold weather.
Old 01-15-17, 12:55 AM
IamLexus
IamLexus's Avatar
VipMotoz is a popular aftermarket headlight that comes with non-hid. You can install HID Kit in them if you want they're H7.
Old 01-15-17, 06:56 AM
LC_Ryan
LC_Ryan's Avatar
will I have to rewire anything or is it just plug and play?
Old 01-15-17, 10:49 AM
IamLexus
IamLexus's Avatar
Its all plug and play the only thing you would have to do is drill a hole on the back cover of the headlights so that the wire can get access. They have a marked the holes for you so it's very simple. They have a video if you need a guide.
Old 01-15-17, 12:03 PM
MikeyK02
MikeyK02's Avatar
This will help
Old 01-15-17, 05:19 PM
LC_Ryan
LC_Ryan's Avatar
and this will work even if I have factory HIDs?
Old 01-15-17, 05:30 PM
MikeyK02
MikeyK02's Avatar
No. When you remove your current headlights, your factory HIDs will go out with them. With this, you would use a HID ballast compatible with the H7 bulbs.
The lights are different
Old 01-15-17, 07:06 PM
LC_Ryan
LC_Ryan's Avatar
I understand that I would have to use a separate HID ballast. What I'm asking is if I take out my current headlights, and put in these headlights following the video, will they work?
Old 01-15-17, 07:13 PM
MikeyK02
MikeyK02's Avatar
Ah I gotcha. No, because they use a different bulb size
Old 01-15-17, 07:15 PM
LC_Ryan
LC_Ryan's Avatar
damn, so I can't just remove my current headlights and put these in. they make this so difficult. is there a way to make them work? splicing wires or something?
Old 01-15-17, 07:21 PM
LC_Ryan
LC_Ryan's Avatar
at this point I want to completely replace the headlight. housing, bulbs, HIDs.
Old 01-15-17, 07:27 PM
Kmasyl
Kmasyl's Avatar
Yes, these are plug and play. I have an 07 that came with Auto leveling lights. I pulled the fuse to prevent the warning light. In addition to the vipmotoz headlights I installed a morimoto 50w hid kit with relay wirenarness. I'm satisfied with the output.
Old 01-15-17, 07:33 PM
LC_Ryan
LC_Ryan's Avatar
ok thank you! I phrased my question wrong so sorry for the confusion.
MikeyK02
MikeyK02's Avatar
If you want to do that. Purchase mine :P
That will replace the headlights, housings, bulbs, HIDs. I went through exactly what you're talking about when I replaced my HID/AFS OEMs.
Mrfouche
07-29-17 04:02 PM
AZ JB
02-13-16 08:02 AM
Leowaxx
06-22-15 09:39 AM
danhtran
07-18-11 08:11 PM
golfpunks
03-06-11 11:59 AM
Quick Reply: head light
