Code error fix
You are experiencing multiple codes although the cause is probably just one part malfunctioning which is causing other sensors to throw codes.
So it looks like the 3 main ones are MAF Sensor, Crankshaft Position Sensor and Cam Shaft Position sensor.
I would certainly start with the MAF. It may have malfunctioned and is messing with your timing and that is why the other sensors are throwing codes. It is located in your air intake pipe (the pipe that goes from your air filter to the throttle body). You can try to clean it or buy a new one. Check youtube on how to clean a MAF sensor if you want to try and clean it first. Just remember you need a special cleaner or you can ruin it. It is very delicate.
This is the exact one that came with the car.
$82 USD
http://www.rockauto.com/en/moreinfo....441482&jsn=355
$82 USD
AaronKL (01-25-17)
$82 USD
$82 USD
You can fix this yourself. It is easy to do. Here is what the part looks like.
http://www.rockauto.com/en/moreinfo.php?pk=5706936&cc=1432808&jsn=329&jsn=329&jsn=329
This is a Denso OEM part that came with your car. I am pretty sure Bank 2 is driver side of engine.
Here is a thread on the issue.
https://www.clublexus.com/forums/is-...ft-sensor.html
